A mate has a problem with his gen 2,, 2 plugs gone down,,tried plugs, coils, ignition loom but still 2 plugs wont fire,,
Possibly an ecu fault.
Anyone have an ecu about,,gen 2 ?
It's very unlikely it's the ECU. The plug caps are really a coil pack i.e. the coil is built into the top of the cap, these can breakdown as can the wiring and multi plug. Check the plug connection for corrosion, fit and test the cap/s.
Later
Yes, bike runs on two cylinders,
Put in a new set of plugs
Put on a new set of coils
I think they have tried an ignition loom too.
So they have taken my ecu from my fz1 back to Wales and are trying it on his bike,,by all accounts the mechanic is shit hot and has tried everything,,it seems the ecu has two signal release ways to the coils, whatever that means, it fires 2 and 2, we will know this weekend,,,,and my winter bike is laid up until ecu returns
04-01-21, 02:55 PM
(This post was last modified: 04-01-21, 06:48 PM by b1k3rdude.)
I take it you swapped around known working coil sticks?
blocked injectors?
