04-08-20, 10:05 PM
Hi Guys, contrary to my handle, this is my second fzs 600 and I'm having a bit of an issue with the cooling system, the problem is, as the bike runs and warms up, it gets to temperature rather quickly, between 8 and ten minutes at idle, the fan will kick on to cool but never goes off. Even on a ride once the fan comes on to cool the water it will not switch off.
I've done a few things to troubleshoot, drained and refilled the system, bled it through thoroughly, I have changed the water pump, which now is definitely working as I can see it pushing the water around with revs at the radiator with the cap off, I have had the thermostat out and tested and is opening and closing as it should, next thing I am going to check is remove and inspect the rad to see if this is blocked at all... But after that I'm at a bit of a loss as to what to check next, any help or direction as to what/where to look next would be much appreciated! Thanks in advance!
