Sump Plug Washer Size?
Hi
Just wanting to know what size is the sump plug crush washer for a Fazer 1000 2003 please?
Just measured a new spare. Outside diameter 19mm.  Inside diameter 13.75mm.  Thickness 2mm
(26-07-20, 05:05 PM)robbo link Wrote: Just measured a new spare. Outside diameter 19mm.  Inside diameter 13.75mm.  Thickness 2mm
Thanks, where did you get yours from?
Local Yamaha dealer. Sump washer, oil filter, seals and brake pads, always use genuine. Could be wasting money, but happy to buy once and it works first time. Fowlers will have one if your local guy can’t get one, but no doubt a common Yamaha size.
Thats great, Thank you
Going onto fowlers website its asking which model of bike , how do I find out which model of bike I have?
hi WAYNE , think that refers to colour, click on one and i think you`ii find the colour pops up , all plug washers will be the same size..
Yep,Mr.Red is correct. However I’ve looked at Fowlers and it’s out of stock, but MSP(Motorcycle Spare Parts) have two in stock. On the crankcase diagram it’s part 25.  Part No.93210-12790
(27-07-20, 11:02 AM)red98 link Wrote: hi WAYNE , think that refers to colour, click on one and i think you`ii find the colour pops up , all plug washers will be the same size..
Hi, for the model there are options like: FZS1000 FAZER (5LVF, 2003) 080 B or FZS1000 FAZER (5LVF, 2003) 080 A, FZS1000 FAZER (5LVF, 2003) 130 A or FZS1000 FAZER (5LVF, 2003) 130 B?
Why not just buy something like this......
https://www.amazon.co.uk/Copper-Muscccm-...ooghydr-21
If you remove the saddle, there should be a sticker on the seat lock strut that links the rear frame rails. That is your paint description code. As Mr.Red has already said the washer is the same for all years and colours.
80 B. Silver
80A.  Dark purplish blue metallic
130B.  Silver 3. etc.
(27-07-20, 06:21 PM)robbo link Wrote: If you remove the saddle, there should be a sticker on the seat lock strut that links the rear frame rails. That is your paint description code. As Mr.Red has already said the washer is the same for all years and colours.
80 B. Silver
Whats the difference between a 80 B silver and a 130 B silver 3?
Foc knows. Mines red and black. No need to worry unless you need to buy paint.
(27-07-20, 09:10 PM)robbo link Wrote: Foc knows. Mines red and black. No need to worry unless you need to buy paint.
I could do with some touch up paint?
RS Bike Paint Ltd in Hatfield, is your best bet.
01707 273219. Have you sorted the sump washer?.
Yes got one sorted now, thanks for your help
