18-07-20, 05:04 PM
Anyone out there fitted a pair of these to their steed?
Never had any issues with standard R&G heated grips, several set fitted, great value and well effective.
'Cos of that thought I'd give the "Premier" heated grips a try as the Oxford ones on my thou' were dead when i had the bike.
Fitted, the grips really are some of the best, nice controller as well.
Wired through an ignition fed relay, work a treat!
BUT........as soon as I start the engine, they turn on, lowest heat setting, can be turned off, but just annoying.
As bought thru' eBay R&G said have to deal with seller, spoke to Demon Tweeks, within 2 days new controller arrived!
Exactly the same fault, ignition on, they're off, start the motor and they auto switch on to low heat.
Wired them up to me car battery, same thing!
Reckon the voltage sensor that turns 'em off if too low is getting confused, and when charging, 13.5V ish, it turns them on.
Waiting now for update from seller / R&G, anyone else suffered same?
