A few spare parts for sale after twelve years of Fazer ownership.
![[Image: Exup-Hagon-S1000r-ignition-Coil-1-4.jpg]](https://i.postimg.cc/52r05FzF/Exup-Hagon-S1000r-ignition-Coil-1-4.jpg)
![[Image: S1000-RR-Shock-Dogbones.jpg]](https://i.postimg.cc/1XSc9d5P/S1000-RR-Shock-Dogbones.jpg)
- Aftermarket adjustable full length brake & clutch levers in silver, fitted the levers to the bike but never even used them on the road £15 inc post.
- Standard master cylinder. £15 inc post.
- Sensor at back of engine block. Errr... will have to find out name of it! Bought but never used £8 inc post.
- 4x mini indicators with 8x fairing spacers / cover plates. Fitted just one but actually preferred the standard indicators with clear lenses. Have the Audi-type directional flashing. I believe they require a different indicator relay fitted, so that they flash at the right speed. £20 inc post.
- K-Tech linear fork springs 8.5nm. Originally for a Bandit 1200 / XJR1300, but a spring is a spring. Longer than the standard Fazer fork springs so I cut shorter spacers accordingly to restore correct internal dimensions. Suit a lighter rider between 9 - 12 stone. £40 inc post.
- Ignition coil for Cylinders 1 & 4, useful spare. £15 inc post.
- Hagon Shock. Standard length and spring for a 'standard' 75-100kg weight rider. Less than a year old, bolts straight on £165 inc post.
- S1000RR rear shock. This shock WILL need disassembled & rebuilt by a suspension company as the damping has gone. Comes with a heavier R6 spring fitted and dogbones which restore the back end to around the standard height. Has an R6 lower mounting bolt and a spacer to go in the lower suspension bush. Preload collar a bit chewed up. Top mount will need drilled out or some sort of top-hat spacer arrangement. £40 inc post.
- *SOLD* EBC FA252 HH front brake pads.
- *SOLD* Full set of stainless steel pistons to suit front blue-spot calipers.
- *SOLD* Yam R1 5jj gear shift. Much quicker / smoother gear changes.
- *SOLD* Head bearing adjuster.
- *SOLD* R1/R6 radial master cylinder with full length & short brake lever
- *SOLD* Beamtech LED headlight bulbs.
- *SOLD* Full Exup valve
![[Image: Yokes-Levers-Sensor-R1-MC-Mini-Indicator...lights.jpg]](https://i.postimg.cc/N0Vb6LNJ/Yokes-Levers-Sensor-R1-MC-Mini-Indicators-Fork-Springs-LED-Headlights.jpg)
