R1 Yoke set
If any of you are considering a front suspension upgrade, I have a complete R1 Top & Bottom yoke set going cheap.
It’s the 4XV/ 5JJ version. I purchased this with the intention of using it, and repaired the Ignition key mounts (see pic) – someone had cut them off with a grinder, probably in desperation and unable to get the original security bolts out.
I eventually used a different version, and wont be needing this one any longer, so its going cheap.
Reasonable condition, with all the original nuts – although these would be different if you’re converting it for a Fazer.
£35 posted, or if that’s not good enough, make me an offer ?
please drop me a pm and we can sort this out
thanks
