30-05-20, 11:03 AM
Does anyone know what I can use or get the rubber caps that fit on the spigot on the pipe inlets?
Pipe Inlet Rubber Cap Thingy?
30-05-20, 11:03 AM
30-05-20, 11:31 AM
Also is it ok to run the bike with one of these missing?
30-05-20, 12:03 PM
https://www.ebay.co.uk/itm/Motorcycle-Va...SwL9Bd-Pmc Do you mean one of these? I wouldn't have thought it would run particularly well with one missing, it'll let excess air into the system.
30-05-20, 12:15 PM
(30-05-20, 12:03 PM)vinnyb link Wrote: https://www.ebay.co.uk/itm/Motorcycle-Va...SwL9Bd-PmcYes there them, thank you, I used to have the scottoiler connected to one, do they not blow air?
30-05-20, 12:16 PM
OEM part number is 16G13569-00, available from fowlers @£2.32 each but P&P will be pricey
30-05-20, 12:19 PM
(30-05-20, 12:15 PM)WayneUK link Wrote: [quote author=vinnyb link=topic=26199.msg315618#msg315618 date=1590836580]Yes there them, thank you, I used to have the scottoiler connected to one, do they not blow air? [/quote] No they suck, the scottoiler works on a vacuum, they're there to attach carb balancing vacuum gauge pipes to.
30-05-20, 12:27 PM
(30-05-20, 12:03 PM)vinnyb link Wrote: https://www.ebay.co.uk/itm/Motorcycle-Va...SwL9Bd-Pmc Do you have a link to buy the clips that go with them , thanks
30-05-20, 12:32 PM
(30-05-20, 12:27 PM)tex link Wrote: [quote author=vinnyb link=topic=26199.msg315618#msg315618 date=1590836580]OEM part number 90467-10039 @ £1.66 each, also in stock at Fowlers. Do you have a link to buy the clips that go with them , thanks [/quote] |
« Next Oldest | Next Newest »
