Rain Issues
The engine in my Gen 1misses quite a lot when its raining hard. I think I need to cut the HT leads down and make a new joint. Am I right I need to unscrew the lead from the cap. cut 5mm or so off and refix
I don't think it can be much else, if I spray with WD45 before I leave the bike behaves much better.
Thanks
Check the drain hole is not blocked also, it's in the side of the head
Drain hole clear.
check for any splits in the ht leadsĀ  , possible
