15-02-20, 10:51 PM
I cant keep borrowing Daves lol, and ive just shimmed the xjr (seven out of spec!) so need to do that. theres a fancy digi one on the bay but its eighty sovs! any recommendations chaps?
best carb balancers?
15-02-20, 10:51 PM
15-02-20, 10:58 PM
Morgan Carbtune has worked pretty well for me over the years.
15-02-20, 11:46 PM
Hard to beat Davida Vacuum Gauges, but expensive. Without doubt the best gauges out there.Not a great fan of the Morgan Carbtune, they have to be held exactly straight upright to read correctly, not always easy to do. They can get a bit sticky over time.
16-02-20, 12:39 AM
I miss the low down pick up of carbs but I'm glad I've got F.I. now.
16-02-20, 12:28 PM
(15-02-20, 11:46 PM)unfazed link Wrote: Hard to beat Davida Vacuum Gauges, but expensive. Without doubt the best gauges out there.Not a great fan of the Morgan Carbtune, they have to be held exactly straight upright to read correctly, not always easy to do. They can get a bit sticky over time. I hang mine off the handlebars, gravity does the rest :lol
16-02-20, 12:41 PM
Morgan carbtune here. Just hang it from the bars. Bought the 4 channel set, so covers all bases.
16-02-20, 04:01 PM
I used to hang the set I have from the left bar and or a cycle stand, appeared to worked fine for a while, but eventuay no 2 would stick. Discussed it with morgane carbtune and still didnt resolve it. Got sick of them and splashed out £135 on the Davida set.Best thing I ever did.
16-02-20, 04:17 PM
Christ. are they worth that? ive got two multis with carbs so I do wanna decent set xjrs apparently need doing quite often too
16-02-20, 04:30 PM
I think they are, I have them over 5 years they are internally damped and definitely well made, the will out last me without doubt.
I had an old cheap set for about 20 years and used to lend to fellows if they needed them, unfortunately at one stage I never got them back.I cannot remember who I gave them to last and anyone I asked said they had given them back. Nobody gets the Davida set, if you want a bike checked bring it to me, but they do not leave my place.
16-02-20, 05:40 PM
18-02-20, 03:30 PM
I've never tried Davida gauges but don't doubt what unfazed says about quality, since he uses them professionally.
That said, I used Morgan Carbtune gauges on all the Fazers I worked on and must have done 500 plus carb synchs without any of the sticking problems mentioned. I found the Carbtune more than accurate enough and easy to use, too. I think you have to ask how many times a year you expect to use whichever gauge you choose to buy and weigh that against the cost and reported durability of each. For a DIY home mechanic, the Carbtune would be my choice.
19-02-20, 08:52 PM
there was a set of davidas, old but apparently sound, on the bay for sixty sovs. they turn up tomorrow...hopefully they will be ok. also tret meself to one of those hang up fuel supply bottles with a petrol tap.
[smg id=3388 type=full align=center caption="scale 307454 340"] These any good Ogri.
21-02-20, 05:08 PM
(19-02-20, 08:52 PM)ogri48 link Wrote: there was a set of davidas, old but apparently sound, on the bay for sixty sovs. they turn up tomorrow...hopefully they will be ok. also tret meself to one of those hang up fuel supply bottles with a petrol tap.After years of foccing around with petrol holders of different I eventually bought a hang up fuel bottle with tap, a great piece of kit, the first few time times I used it I wondered why I didn't buy one years before. No more petrol leaking or carbs running out of petrol while balancing them The folding bicycle stand is great of holding it and the vacuum gauges. Ogri48, Did the Davidas arrive?
25-02-20, 09:38 PM
yes mate. needed new hoses, but work fine. and Christ they are good; I can see why they cost a lot new. made it a really bloody quick and simple job, even for a twat like me. Bike absolutely purrs now lol ;-)
25-02-20, 09:39 PM
and yeah, the bottle fuel tank is incredibly helpful, best tenner I ever spent
25-02-20, 10:38 PM
Those Davidas are well made indeed. :thumbup Really solid bit of kit.
29-02-20, 04:47 PM
Hi Ogri,
Where do you get your fuel cell from. The only cheap ones I can find will take ages to arrive as from India. Thanks in advance.
29-02-20, 06:24 PM
Demon Tweeks is where I got mine, but M&P may do them.
01-03-20, 12:42 PM
mine came up new in the bag but secondhand mate on e bay, some feller bought it but never used it
« Next Oldest | Next Newest »
