Too many unfinished projects, currently have to clear a path through the garage, so some stuff has to go.BMW S1000RR rear shock, longer brown top version. Top preload ramp screw (Torx) replaced with a stainless allen head bolt. Sadly no washers for the top mount, but choice of dogbones - either a set to put the rear-end back at standard height (150mm) or slightly longer dogbones to lower the back-end around 20mm (155mm - pictured). Also, apart from standard BMW spring I have a spare spring in black, which is rated 650lbs/inch, suiting those who are more 'big-boned'
Downside is that it's only 6 inches long, so *might* require a spacer - not sure, never got a round to swapping it over...
SOLD
SOLD
![[Image: S1000-RR-shock.jpg]](https://i.postimg.cc/cLsZzJ29/S1000-RR-shock.jpg)
