Have I f***ed it?
HELP
So, just left my bike ticking over in the garage for about 15 minutes. When I went back the temperature warning light was on and the gauge said 122 degrees. Turned it off straight away and could hear the coolant boiling. I assume the fan must have failed...
What are the chances I have f***ed it and what is the most likely outcome - head gasket?
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
I reckon it will be fine mate. relatively modern engines have to cope with all sorts of extremes in other countries. aside from major mechanical issues they are pretty bulletproof (and thankfully for moi, fairly idiot proof too) Wink
Fingers crossed it won't have done any major damage.... was scary to hear the coolant boiling.
Have just tested the fan and it has definitely failed.
Anything I can do to check there is nothing seriously wrong?
(06-12-19, 09:07 PM)teecee90 link Wrote: Anything I can do to check there is nothing seriously wrong?
Not trying to be clever but I would say take it for a ride and if it runs o.k. then you will be fine.
(06-12-19, 09:11 PM)limax2 link Wrote: [quote author=teecee90 link=topic=25797.msg306207#msg306207 date=1575662825]
Well yes, but the fan has failed so don't really want to risk that until I get a replacement so was wondering if there are any other checks I could usefully do in the meantime. Fowlers want £378 for a new one..!
Doubt the fan would come on in normal riding this time of year so ok to test. Is the thermostat stuck closed?
Have you tested the fan to be sure it's that and not something else causing it to not come on?
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
The fan is probably ok. It's more likely that there is a leak somewhere in the cooling system so the cooling system is losing pressure and that caused the coolant to boil over at a lower temperature than it should. If there's a leak the coolant could boil over before the fan comes on. I'd dry the bike off, fill the cooling system back up and start it up and look for leaks. Look for any drips or wet areas. The o ring on thermostats can fail. Looking at the wiring diagram. You could test the fan by pushing a bit of wire into the green/black connection on the fan relay, then touch the other end of the wire to the negative of the battery or the frame of the bike, the fan should come on. That will test the fan fuse, relay and the fan
Could be the rad cap not maintaining sufficient pressure to stop the coolant boiling.
Quote:When I went back the temperature warning light was on and the gauge said 122 degrees.
There's a temperature warning light - but a gauge?
I have a multi gauge which shows the temperature.
Fan is definitely shagged. I disconnected the plug to the fan under the tank and used a power probe to send 12v direct to the fan and nothing.....
did you ground the other pin at the same time?
Ah, got you.
Make sure you got a good clean connection with your probe etc etc.
Quote:Fowlers want £378 for a new one..!
If your fan has expired there are loads of used ones on e-bay.
EBAY  ITEM NUMBER 163799706299 £37
I can sort the fan out. My main concern was the possibility of anything more serious. I guess the most likely thing would have been the head gasket, but there is no evidence of coolant in the oil so far, so hopefully ok and a change of fan is all that’s needed.
Anybody else ever had a fan go like this? Bike is a 2003 with 31,000 miles. I suppose I should have noticed as the fan usually kicks in quite early when the bike is idling stationary.
If it helps, the manual for my fz8 says if the temperature reaches 130 degrees pull over and stop.
If you only got to 122 I reckon you're OK.
Ok, so something strange is going on. Started the bike this morning and it seems to run fine, but the fan didn't come on at all while the bike was idling. As soon as I revved it the fan came on, but not at full speed. As soon as I stopped revving it the fan stopped again and wouldn't run regardless of the rising temperature gauge. Revved it, and the fan started up but again not at full speed. Not sure what is going on here.....
I think you have high resistance in the fan circuit and that's causing low voltage and low current at the fan. When you rev the engine it raises the voltage and current enough to start the fan turning but the voltage and current are still lower than they should be because of the high resistance so the fan is spinning slower than it should. I'd guess there's corrosion in a connector or wire.
To confirm it you could measure the voltage at the fan when the fan is spinning. The fan has to be spinning for the voltage test to be accurate because there has to be current flowing through the circuit. You should be seeing close to battery voltage on the fan connector when the fan is spinning but I think you'll see lower voltage because of high resistance. Basically in a good circuit all of the voltage should be dropped across the load which in this case is the fan but because there is added resistance in the circuit some of the voltage is dropped across the added resistance and what's left is dropped across the fan. If you find low voltage on the fan connector you can determine if the resistance is on the 12V wire or the ground wire by leaving one probe in the positive wire of the fan and touch the other probe to the positive of the battery. On a good circuit you should see close to 0V, if there's added resistance on the positive side of the circuit you will see some voltage on the meter so you know then that the problem is on the positive side. You can then do the same test on the ground side of the fan. One probe in the ground wire of the fan, touch the other probe to negative battery terminal. On a good circuit you should see close to 0V. If you see voltage, there's resistance on the ground side of the circuit. Again the fan has to be spinning for it to be a valid test.
(15-12-19, 04:19 PM)His Dudeness link Wrote:I think you have high resistance in the fan circuit and that's causing low voltage and low current at the fan. When you rev the engine it raises the voltage and current enough to start the fan turning but the voltage and current are still lower than they should be because of the high resistance so the fan is spinning slower than it should. I'd guess there's corrosion in a connector or wire.
Thanks for the advice - I've just ordered some back probes for my multi-meter and will give this tests a try. Cheers
thats a helluva helpful reply dude, respect. I do love learning summat too... Smile Smile :thumbup
