Fuel pump noise fzs600. No front wheel speedo drive ,lack off grease
Anyone has to swap their fuel pump mine gets really loud at 30mph ,at least I presume its the pump
Its either a high pitched wine like wind through a visor or rattle like the relays fked
Odd. I would have thought the pump noise wouldn't be related to road speed.
Could be the speedo drive in the front wheel? Makes a terrible whine if not enough grease
As a test you could temporarily unplug the connector to the pump and listen if the noise goes away when it's unplugged. If the noise goes away the problem is most likely the pump, if it's still there you know the problem isn't the pump. The bike should still run ok with the pump temporarily disconnected
(25-11-19, 07:38 PM)mtread link Wrote: Odd. I would have thought the pump noise wouldn't be related to road speed.
Finally had time to remove speedo drive ,this was bone dry packed with grease ,noise gone
Thankyou for the advice
You're welcome. What this forum is all about  :thumbup
