Model changes
Does anyone know if there were slight model changes between the years 1998 and 2001? I'm after getting a used replacement cowl stay and the mounting for holding the clocks is at a much steeper angle than the original - so much so that the clocks foul the ignition switch and can't be fitted. It's a used part so could have obviously been bent but it doesn't appear to be the case.
Same Stay on all the boxeyes, only changed for the Foxeyes.
(28-10-19, 08:49 PM)unfazed link Wrote: Same Stay on all the boxeyes, only changed for the Foxeyes.
Hmm...is the foxeye completely different looking?
Mounting point on frame is the same. Post a picture of what you have and I can tell you.
(28-10-19, 09:22 PM)unfazed link Wrote: Mounting point on frame is the same. Post a picture of what you have and I can tell you.
The one I'm after getting is exactly the same as my original except for like I described - the mounting bracket for the clocks is at a much steeper angle so the clocks end up fouling the front of the ignition switch.
98 Boxeye  https://www.bike-parts-yam.com/yamaha-mo...37/0/23948
03 Foxeye  https://www.bike-parts-yam.com/yamaha-mo...37/0/24254
(28-10-19, 11:56 PM)mtread link Wrote: 98 Boxeye  https://www.bike-parts-yam.com/yamaha-mo...37/0/23948
Ah yeh...totally different...thanks. I'll be bringing the one I'm after getting back.
