bike fails under load
Well this is a new one on me, the bikes been running crap recently, cut a long story short I've not had the time or the inclination to keep on top of the maintenance for a while now.
Anyway, she (the bike) starts ok but as soon as I've put her in gear and tried to move off the revs die off and the engine cuts out.
When she's running she sounds like a sewing machine, camchain rattling like a good 'un but that's another story.
The bike used to take a bit of choke to start, now it's the opposite- the choke needs to be off and the revs at zero before the engine kicks into life. Another thing, once the bikes idling at stationary, if I rev the bike hard the engine cuts out. Any Ideas on where to look, as I've said if anyone can save me a bit of time with this one it's much appreciated  Smile [size=78%] [/size]
When was the last time you changed the plugs, it's the first place i would start?
Is it running on three cylinders?  If you're not sure you could do the water on the headers trick to find out. Start it, let it warm up, throw some water on the headers and see if one of them dries a lot slower than the others. If one dries slower, that cylinder isn't running properly. Then you have to determine if it's a spark or fuel problem on that cylinder. Take the plug out and check for spark. If you've got good spark it's probably a problem in the carb. If it's been parked up on the side stand in the rain there's a good chance the problem is on cylinder 3. Rain water collects around the spark plug on cylinder 3 and causes problems. Another thing. Start it when it's dark and look for arcing around the plug caps. You'll see small blue arcs between the plug caps and the head
Cheers Gents, if my memory serves me right I replaced a single plug a while back as it was firing only on 3, lets' hope I really don't want to take the carbs out again if I can avoid it. I'll have a fettle when I get some time  and let you know the outcome!
i would be looking at the air filter first and giving a quick blast with the vacuum if you havent got access to compressed air
its the not needing the choke that makes me think that as it increases negative pressure in the venturi and pulls in more fuel
hopefully the cam chain rattle is just cause by the tightener to be just before its next click
