Gear indicator installation .Where is the crankshaft Position sensor connector
As per title. FZS 600 2002 Foxeye.
Does anyone know where the 2 pole connector is located so I can wire in green wire from the indicator and what are the colours of the wires in the connector?
A picture would be nice. I've looked for videos etc on you tube but cannot seem to find where it is situated.
Cheers.
I had this saved, but I’ve not viewed it yet so don’t know if it’s helpful or not ?
https://youtu.be/GJHS-JbDt-k
Thanks for that. It started well, filmed in the daylight but at 2.45 it went a bit pear shaped as it is then filmed by torchlight and not very well. I'm not convinced the guy has connected to the correct wire for the crankshaft position sensor as in some written instruction I managed to find from Healtech say the connection is made to the grey wire in a two pole connector which is located behind the seat locking mechanism.
I bought mine from Aliexpress for 38 dollars and although not as advanced as the Healtech, which does cost a lot more, it works OK.
https://www.aliexpress.com/item/32888816...4c4dnsQPQa
Thnkx for feedback on video. Looks like one for the bin.
