Mistake on the 98 wiring diagram?
If you look at the ignition in the 98 wiring diagram http://foc-u.co.uk/index.php?action=down...iew;down=8
The diagram shows a connection between the blue wire coming off the ignition and the black wire going between the alarm and the ignitor. Is that connection a mistake?
(12-07-19, 06:52 PM)His Dudeness link Wrote: If you look at the ignition in the 98 wiring diagram http://foc-u.co.uk/index.php?action=down...iew;down=8
Looking at the diagram, I canot see a blue wire coming from the ignition. I can see a black wire that connects to the black wire to the igniter/alarm
There's a blue wire L coming out the bottom of the ignition in the diagram. The diagram shows a connection between the blue wire and the black wire going between the alarm and the ignitor. I'm just wondering if there should be a connection there or is there a mistake in the diagram? It looks like a mistake to me but I'm not sure
All the wires going to the alarm are black. It looks like a switched live from the ignition.
I think the black is a ground going back to the ignitor. That black connects to the black directly below it in the alarm. So it's a ground when the side stand is up and the key is on. The blue is 12V coming from the light switch and going to the tail light. I don't know why you would connect the light switch 12V to the ignitor ground. Wouldn't that just short the light switch? I added a pic of the connection.
[Image: s0xzsh.png]
Definitely a mistake and there is a second a mistake and both are repeated on the Haynes manual.
.jpg   Incorrect.JPG (Size: 62.92 KB / Downloads: 34)
Corrected one with the alarm loops in
Not the best resolution but does this help at all? Also excuse the number key I used for rewiring mine.
Corrected colour diagram for verification with loop plugs shown
(18-07-19, 01:16 AM)unfazed link Wrote: Definitely a mistake and there is a second a mistake and both are repeated on the Haynes manual.
Nice one. When I was trying to figure out how the alarm is connected I saw that and thought that's a funny loop :lol Now that you pointed it out, the way it was drawn it would make the connection through the alarm pointless because the ground from the starter switch already goes straight to the cut-off relay :lol
I think there might be another small mistake on the black and white diagram. See the female connector going to the fuel pump? It says L/Y and B/Y, I think it should say L/B and B. And the female connector on the sidestand switch says L/Y and B/Y and it should say L/Y and B
I noticed that last night when looking at the diagram, it is wrong also on the 00-01 supplement, but codes are correct on the 02-03 supplement.Looks like somebody did a copy and paste and forgot to change the codes  :lol :lol :lol
You can almost follow what the engineer did when he was making the schematic. Copy this, move that there, biff baff boff job done I'm off home see yas on Monday :lol 21 years later......does that connection look right to you :deal :lol
:wall :oops Ah Foc! No one will notice it  :rollin
If everyone who is reading this is happy with the changes I will upload the corrected diagrams to the Downloads section.  Confusedmokin
