Clutch not working
I've. Found a problem today. On my 2001 I can't pull the clutch in fully it goes hard before fully pulled I can engage and disengage gears just feels wrong ..I'm not sure if it's the worm mechanism not working correctly
Unbolt the front sprocket cover from the bike. Pull the clutch lever. Is it smooth and free when you pull it or is it still stiff? Most likely is that the cable is freyed and binding.
https://www.wemoto.com/bikes/yamaha/fzs_...inky_glide
Thanks guys I did order a new cable yesterday hoping it might be that simple so I'll give it a go once it arrives . It feels no different with the cover removed from the bike
Pop out the rubber bung on the sprocket cover and check the adjuster and locknut haven’t loosened off.
If it’s not set correctly there then you could reach the endstop before the pushrod is able to operate the clutch, though you’d also be running out of adjustment at the handlebar.
(24-06-19, 08:15 AM)Ginger pig link Wrote: Thanks guys I did order a new cable yesterday hoping it might be that simple so I'll give it a go once it arrives . It feels no different with the cover removed from the bike
With no change with cover removed than as others have said cable or the mechanism in the cover binding.
Have a read of this, and grease the bearings in the cover while it’s off, it’s well worth doing.
http://foc-u.co.uk/index.php/topic,10124.0.html
(24-06-19, 01:21 PM)darrsi link Wrote: Have a read of this, and grease the bearings in the cover while it’s off, it’s well worth doing.
thanks for the advice guys and I'm certainly going to do that greasing ,I recently replaced the front sprocket and the 9mm nut was still in place so I replaced the nut and washer with the 12mm upgrade ,I cleaned the case thoroughly was a bit of a mess greased the ball where the push rod goes wasn't aware of the method to grease the actuator ,HAVE TO HOLD MY HANDS UP I'm a dick head clutch problem sorted the bike has Oxford heated grips fitted and the grip had drifted around the bar and the wiring shroud was interfering with the clutch lever can't believe I didn't spot it yesterday as they say walk away and start afresh the next day .SOA few quid on bits will teach me a lesson in the future ,lol now for some adhesive to fix that bloody grip
