Replacing footpegs
Hello guys.I have a FZS600 1998-1999 and need to replce the rider“s right footpeg.I ve seen some tutorials on youtube, and most footrests have either a coter pin or a U shaped o-ring to be removed  to remove the bolt. However my bike has none of those. There are some videos where bolt is cut with a saw. Is that the way to do it?
Also, are there any videos or tutorials on how to replace the brakes pads on this model?ThanksMiguel
I only took the other side off but take off its carrier and then to the rear its held on with a big allen bolt that is as tight as foc with threadlock, I had to put the whole lot in the vice to hold it.
