Removing Centre Stand - Spring Hints Welcome
Watcha
Any hints to make life easier getting centre stand springs off and on again?
Cheers.
Jam a washer or penny between each wind of the spring. I’ve used this method a few times and minimises the risk of injury when trying to stretch them on.
Just undo a bolt on one side and it will all become obvious.
When refitting put one bolt on, then you can quite easily pull the stand across for the other bolt to be put in place whilst stretching the spring at the same time.
The only fiddly part is the fact that it’s in an awkwardly low place to manoeuvre.
:agree
Though I would add, it is easier, and safer, if you get a friend to sit on the bike with the brakes on.
Brill, many thanks.
I've got it on front and rear paddock stands.  Good access, but was worried about pulling it over! (needn't have been)
Wire wheel, Hammerite, grease, refit.
Ta.
Heres mine i did a couple of years ago http://foc-u.co.uk/index.php/topic,20049...#msg231855
(09-04-19, 05:24 PM)fazersharp link Wrote: Heres mine i did a couple of years ago http://foc-u.co.uk/index.php/topic,20049...#msg231855
Cracking job, mine won't be that good.  Good hint about the ACF50
Mine was a pig to get off.
Just getting the bolts out required a lump hammer.
Spring was also a nightmare, even using the coins trick.
A spring puller might make life a little easier.
-suck-squeeze-bang-blow-
(09-04-19, 10:33 PM)Bretty link Wrote: Mine was a pig to get off.
With one bolt in on one side of the stand the other side pulls into place quite easily with the spring attached, there's no need for any major or extra attention to the spring itself.
