Daft flywheel question ??
Does the flywheel run in oil or is it in a dry space ? thanks for looking ---
MY GRANDAD TOLD ME -WHAT DOESNT KILL YOU MAKES YOU STRONGER--EXCEPT FOR A BEAR THAT WILL DEFINATELY KILL YOU---
There shouldnt be any oil there
I don't know about the FZ6...
But by flywheel do you mean the big toothy steel ring on the back of the clutch basket? If so your clutch is in oil and there will be oil there...
Or do you mean the rotor usually on the end of the crank shaft / left hand side of the engine. This is usually dry and not in oil.
-suck-squeeze-bang-blow-
Thanks sorted now --
