FZS 600 For Sale Come Spring
This is out there in case you are looking for a nice FZS 600 Fazer Foxeye later in the spring.
Not now but in April when the FZS600 Foxeye needs a new MOT it will be up for sale.
I am leaving it until then as it will command a higher price come spring.The Fazer FZS600 is in hibernation right now and it was given a good service before going to sleep for the winter.
It included:
Oil and filter change, Shell 4T Semi Synthetic.Plugs cleaned (Did not really need doing, as only done about 2,000 miles since being replaced) Air filter changed. Fuel stabiliser added to petrol tank. Chain Cleaned & Lubed
Fazer  FZS 600 Foxeye
Silver2003 Registered.
37,754 Miles, MOT’ed until 23rd April 2019. Will come with a new MOT.
Battlax Tyres, T30F Front covered 300 miles, BT201R Rear 1400 miles.
**  New Rear Shocker Nitron R1, 400-500 miles
**  New Front Fork Cartridge Emulators (YYS) and new Ohlins Linear Springs, 400-500 miles
Front Fender Extender Carbon Look.
Twin LED Spot LampsLED Side Lights.
Ultra Bright Hint of Blue Head Light Bulbs.
LED IndicatorsBlue Braided Stainless Steel Brake lines front and rear. (Cobra)
Clear Flip Type Screen.
Blue Screen Screws
Stainless Steel Down Pipes
PipeWerks Stainless Sports Can and Link Pipe.
Stainless Steel Radiator Cover.
Blue Stainless Steel Engine Case Screws.
Blue Billet Oil Filler Cap.
12 mm Front Sprocket Nut and Washer Fitted 4[sup]th[/sup] Feb 2017.
Chain and Sprockets Good.
1K Fazer rear caliper 'Blue Spot' and new pads, Fitted 200 miles ago + 1K Fazer Alloy drilled caliper torsion arm.
Front calipers serviced spring 2018.
Bridgestone Batlax T30F Front & BT201R on the rear. Front tyre 100 miles, Rear tyre 1500 miles.
Bike very clean and looks smart.
400-500 miles ago I spent £630 on full suspension upgrade. See ** above.
Now set up for a 90 Kilo fully togged up rider (14 stones including riding gear)
Bike will not be ridden before April, when it will be taken for MOT, but is started up every two-three weeks and brought up to temperature.
Comes with:
Yamaha Handbook, Haynes Manual, New Oxford Aquatex Cover, Oxford Battery Conditioner/Charger. Original Yamaha Screen, Original Yamaha Silencer. Spare 12mm Front Sprocket Nut & Washer, New 15 Tooth Renthal Front Sprocket. Disk Lock, Ground Anchor Chain, Brand new set of carb balancing gauges.
Registration Document & New MOT.
Looking at £1,800 in April.
Or now if you want to buy it now that good but its still £1800, but I will still put new MOT on bike for purchaser. Will equal 13 months MOT.
