Hand guards
Can we get hand guards for my FZS 600 I would use my heated gloves but my battery screws are not long enough
Don't think you can get hand guards been mentioned before, just get some longer M6 bolts for battery terminals, put nut on bolt up to head cut bolt length required then remove nut which should clean threads & remove burrs.
No hand guards will fit I have looked into this quite a lot. The problem is that they all touch the fairing towards a full lock, someone on here has moved the fairing forward to accommodate and I think they still slightly touched.
I've always wanted hand guards on my bike, but they simply won't fit.
I inherited my '03 with hand-guards and they seem to fit fine, it's gone through 6 MOTs and no one ever mentioned anything.  No idea of the make but they look very plasticky, I guess they 'just about' touch the fairing but it's never given me an issue.  Since I changed to Renthals they've not been secured to the ends of the bars, just on the brake/clutch bolts, but they don't flap around much.
I can't imagine riding without them in winter, even with my heated grips... I'll try and get some photos over the weekend.
Eagles may soar, but weasels don't get sucked into jet engines...
(11-01-19, 02:18 PM)Buzz link Wrote: I inherited my '03 with hand-guards and they seem to fit fine, it's gone through 6 MOTs and no one ever mentioned anything.  No idea of the make but they look very plasticky, I guess they 'just about' touch the fairing but it's never given me an issue.  Since I changed to Renthals they've not been secured to the ends of the bars, just on the brake/clutch bolts, but they don't flap around much.
You MUST have your fairing positioned more forward somehow, i can’t see how it would be possible otherwise?
Absolutely no chance on my bike.  :\
:useless I think that its a bit easier on a Foxeye --- is it a foxeye at 03 ? also is it possible they were after market bars to start with.
Here are some rubbish pictures...as I said, if I actually attached the guards to the bars then there would probably be about 1/2 cm restricted travel to full lock but seeing as I've also got short levers the fact the guards are pushed back a centimetre or so doesn't seem to matter. I've not failed an MOT anyway.
[Image: 20190113-114543.jpg]  [Image: 20190113-114551.jpg]
Maybe turn the phone sideways and stand back a bit?
All looks a bit tight still, but hard to tell?
They look like suzuki v strom hand guards which I have researched myself in the past for my boxeye.
If you had bar ends fitted then the open "U" shape is supposed to clip onto the bar end weights. From the pictures it looks like you do not have bar ends so that the u shape without bar ends fitted now floats further towards the back of the bike meaning that the guard also sits closer to the leaver and so bringing it clear of the fairing on full lock. And the reason you can get away with doing it like that is because you have shorty leavers. Otherwise the guards would touch the fairing even with the non OEM bars.
Have I got that right, and going by the mirrors looks like yours a Foxeye.
I am interested to hear that they do not press in at speed despite the lack of the end fitting. Personally I am not brave enough use them like that just incase any "off" resulted in an examination of the bike and it was used as an excuse not to pay out.
https://www.ebay.co.uk/itm/YAMAHA-FZS600...:rk:1:pf:0
Anyone tried the above?
(13-01-19, 05:47 PM)fazersharp link Wrote: They look like suzuki v strom hand guards which I have researched myself in the past for my boxeye.
Yes, it's an '03 Fox-eye. When I first got the bike back in 2012 it was fitted with standard levers, standard bars with standard bar-ends and there was still no problem with the guards on full lock, not that I noticed with it being my first bike, plus I wasn't "full locking" with any confidence anyway.  I fitted Renthal 758s with the shorty levers about 4 years ago but never got round to fitting bar-ends as the originals didn't fit, it seems to make no difference with the buzzing having ends or not to be honest.  Also as I do a lot of riding in London the wider Renthals with 2 inch bar-ends isn't a desirable combination...
