Bike wont start when hot
Hi guys sorry my second post is looking for help
i have a 2011 FZ8 16k miles full history seems a well looked after bike
only got it yesterday.
well here issue.
i went to look at the bike the bike was stone cold, it fired up no problem at all stopped and started it 6 or 7 times no issue.
rode it fairly steady about 45 miles everything seemed good, stopped in town to show my wife was there about 20 mins went to start it, nothing hit the button not a peep, every time i hit the start the EML illuminates.
i turned it on and off for about 10 mins then it fired into life and i rode 10 mins home when i got there, same again wouldn't start messed abot 2 or 3 mins then again fired up.
i then left it until this morning a first touch it fired up no problem i then just left it to tick over and get up to temp againg started and stopped it abou 15 times no problem.
i then waited for it to reach 101 degrees the fan cut in, hit the button and it was again dead.
it took about 25 mines before it would start again temp went down too 56 before it would restart.
i then left it running it then got up to 103 i turned it of but this time it started ok i started it about 6 or 7 times when it was over 100 degrees i then pushed it back in the garage and scratched my head  :rolleyes :rolleyes :rolleyes :rolleyes
any help or pointers greatly appreciated
Dave
Does it turn over or is there nothing at all?
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
(17-11-18, 10:10 PM)celticbiker link Wrote: Does it turn over or is there nothing at all?
nothing at all completely dead  :rolleyes
It's the starter relay then.
Six quid and half an hour will have it fixed.
This can be tested if you are competent with mechanics/electrics in quite literally 2 minutes.
(18-11-18, 12:45 AM)celticbiker link Wrote: It's the starter relay then.
old one removed, new one ordered £18 so has to be worth a try
little bit concerned as the one i removed had no identification or writing on it all, so worried its an aftermarket part
that someone already replaced to try solve the problem Sad
Did you buy an oem or an aftermarket one?
Did this cure the problem?
(25-11-18, 01:18 PM)celticbiker link Wrote: Did you buy an oem or an aftermarket one?
Hi Mate yes after market one it seems to have cured the problem run the bike up to temp starts every time although have not actually used it since so fingers crossed
Excellent, thanx for the feedback.
i used these guys for the parts decent prices quick delivery  Smile Smile
http://www.brooksbarn.co.uk/
Just a thought, check the fuse in it. Mine came with a 30 Amp which is way higher than required.
