07-11-18, 10:28 AM
Hi guys, hoping for a little advice about my 2nd bike, a '91 Yamaha SR125 that I've picked up for cheap so I don't drop my Fazer when riding in the ice and snow.
It doesn't run currently and the problem seems to be the coil (way off spec according to the Haynes). All the replacements I can find online have "12v CM11 50" on the side, whereas mine has "12v CM11 55".
As far as I understand it (which isn't well), the 50/55 bit relates to the distance between the posts where it mounts to the frame? The only other difference I can see is that the "50" ones have bullet connectors, whereas mine has a 2 pin connector.
I know I can file the mounting bracket to fit, and change the connection on the loom to bullets, but I don't want to do that if it's not going to work!
Any advice? (example below of the "50" type)
https://www.ebay.co.uk/itm/Ignition-Coil...0033.m2042
