03-08-18, 07:35 PM
Hi,
I have 'Y' plate FZS 1000 - as previously owned and improved by DevilsYam who I believe is no stranger to this good site.
Anyrate - I'm seeking some advice / guidance please.
Bike was running perfectly. Came out earlier in week, turned ignition key and absolutely nothing, no lights, no clicks or burrs...zilch.
Did a bit of research on this forum and initial feedback seemed to be battery. It was sitting at ~12.2 V unloaded (couldn't load it). I have had it on charge via Optimate and it's now at over 13V (charger still connected) - but still absolutely nothing when I turn the ignition key.
I've checked the fuses - all fine. I also have voltage at the main fuze when the ignition is turned which could suggest the barrel is OK??
I will remove plastic and tank tomorrow to see if there's anything obvious. I will also have a quick look and clean in the kill switch. May try a jump too.
However, my main question is: "does the fact that I get absolutely nothing point to a specific culprit - is there a relay which is the very first thing in the circuit (after the fuze)?".
I'm more than happy to buy a battery - but it doesn't 'feel' like that at the moment although I appreciate these can be digital in their behaviour.
Thanks
Doug
