Hi guys, I have just balanced the carbs and then checked the TPS, the reading was 10, I read on here it should be 5 so I have adjusted it to 5.Looking through the Haynes manual it says the 5 setting is for bikes before 2003 and the later bikes you have to measure the resistance on the wires.Does anyone know if I have done wrong?Cheers John
"Scattered showers my arse"........ Noah
30-07-18, 09:37 PM
(This post was last modified: 30-07-18, 11:21 PM by ProdigalSon.)
Ok I'll show my ignorance, why is there even a throttle position sensor on a non fuel injected bike? :rolleyes
I actually meant non fuel injected bike, why do you need a TPS on a NON fuel injected bike? :lol
Because if you disconnect it the bike wont run!! :rollin
Ah ha, so linked to the Exup valve, thanks Mike for actually coming up with a non patronising answer as if I had known I wouldn't have asked. It's been a long time since I've had a bike with carburetors and they certainly didn't have them on the bikes I did have back then. :lol
Thanks for the replies guys
