do I need to replace front sprocket nut
Hi,
Bike fitted with 12mm front sprocket.
If and when I need to change chain and sprockets front/rear.
Do I need to replace the present 12mm nut or can I re-use present nut....
You can reuse the 12mm nut if threads are ok,just make sure the washer is good to bend to lock the nut.
If required,
https://www.wemoto.com/bikes/yamaha/fzs_...t_kit_oem/
Actual recommended torque setting for the newer 12mm nut is 90Nm, but a few of us thought that might be a bit risky due to the thread issues so only used 80Nm with a bit of Loctite, as well as the washer.
9mm nut was 70Nm if memory serves me correctly.
