FZ1n indicators
hi ,
whats the best clear or LED indicators for a direct fit for the FZ1 ?
basically looking for plug n play so no messing around with wires etc.
cheers
(15-06-18, 08:04 PM)fizzer999 link Wrote: basically looking for plug n play so no messing around with wires etc.
Real simple and cheap - replace the stock bulbs with LED like I did, these bulb ware bright to enough replace 10 and 21w indicators bulbs, you will also need a LED friendly indicator relay - Also in my case I am running BikeIt indicaters because a) they are smaller and b) because the stalks are rubber so bend in a spill and unlick stock, so wont crack your fairing. And indi-spacers, which I put a small hole in for the little lug on the indicators that stops the indicator from rotating - Total price is cheaper than most4x dedicated LED indicators, and I can take a little video of mine of you lik.
I recently bought an adjustable indicator relay - pretty much the same as the bright orange one at £1.99 in b1k3rdude's link (except mine cost 99p inc post from China which is ok if you can wait 6 weeks for delivery). I bought 5 which wasn't so daft as the first one I tried didn't work!!!
I had to make up extension wires to get it to fit - most of these relays won't just plug in without any modification.
thanks guys , was looking to get away from the big originals , what do you reckon on this set up ?....https://www.ebay.co.uk/itm/Yamaha-R1-R6-...1438.l2649
They will be fine mate. I ditched the originals a few months back in favour of L.E.D and they are so much better.
I went for the Oxford saturn ones as they were some of the best looking but I wouldn't recommend them as they all had to be glued back to the rubber mounts after about 6 weeks.
Have a look at the 2015+ R1 indicators, they are priced but very nice
thanks ,
my next question is where is the flasher relay on a 2010 fz1n ?just so I dont strip parts off I dont need to  Smile
found it  :rolleyes
