WANTED - FZS 600 98-03 Ignition coil cover
Hi all, i'm in need of the rubber cover that goes over the left hand side ignition coil, i'm getting water ingress and she's running like a three legged donkey on stilletoes in the rain, please help me!
Would it be possible to coat your existing cover with some silicone sealant and fill in any gaps while you get a new cover?
Thank you for your suggestion, the problem is when i bought the bike the previous owner had customised it heavily & in doing so had removed ALL the bikes protective rubbers, i am slowly replacing them one by one, but the main one i need is the ignition coil cover.
do you mean the crap flap that rests on the cam cover?
Not that one unfortunately, it sits over the ignition coil on the left hand side, it's a rubber cover to stop side spray.
It's part no* 4 on this schematic
.jpeg   010AE54E-3874-44E3-8716-0508F009367E.jpeg (Size: 206.95 KB / Downloads: 17)
Ah. In that case I think you will need to make something yourself until you can get one.
You read my mind, i've just ordered some Sugru (moldable glue) to fashion a replacement.
I'll let you know how i get on?
But if some kindly Foccer happens across an original one at some point i'd snap it up!
