Rusted now rounding bolt on powervalve
Hi Guys
I'm a bit concerned about the bolt holding the powervalve cover in place on my bike.
Last year I had problems with the YPVS fault 'code' appearing on my tacho - so I adjusted it and lubed everything up, went pretty well. I had to renew the pulley because it was in really shit state - and I mean that - worst working part I've seen on any running bike. I wanted to take the cover off and check the actual valve flap operation and clean if ness, but this one bolt head was rusty and the bolt started rounding - it was crazily overtorqued. I left it, rather than cause damage that would affect the valve access. Was hoping a friend would sort it for me, but so far it hasn't happened.
After the error code started appearing again recently (sorted now, though, with tightening of the cables) I really want to get inside that valve housing and check it over.
Would I be okay just cutting a slot into the bolt head and using a large screwdriver to unscrew it (my usual method) or is it a really long one that would be difficult to remove this way? Really don't want to end up having to drill it.
TiA
I'm out of the country at present but if you search my posts I've posted the length/dimensions of all the necessary exup bolts. I do hope you don't have to resort to drilling it out. Good luck
:thumbup .
From what I remember they aren't that long. If you can cut a slot into the head it is always worth trying, or hammer on a slightly smaller socket - sometimes using those old Whitworth Imperial size sockets can help as you can get some which are half a mm smaller, always worth a go.
I really hope you don't have to drill but if you do then please use a decent drill bit because it will save on all that swearing that I used to shout when I used cheap drill bits!
However... Mine were OK to get out - only to find the ones underneath the cover for the EXUP valve were totally shot.
The sizes of the bolts are in the FAQ.
Thanks a lot for the adviceĀ  Wink
