10-05-18, 06:56 PM
Looking for some guidance on removing the Compression Damping adjuster assembly from the bottom of the forks. I’m planning on replacing fork seals, and getting the outer fork tubes painted while I’m at it (they’re looking rather shabby).
The Haynes manual gives me all the info on fork disassembly, (a procedure I’ve done before on other forks), but no insight into removing the adjuster – only has details on the actual adjustment itself. I expect that its not necessary to remove it for changing seals, etc. but I would prefer to take it out for the tube painting, rather than taping it up.
Is it just a question of undoing the main body (looks like a 19mm spanner) ? Whats behind it ?
Any info would help ! Thanks !
