WANTED, 5 mm coolant pipe for FZ600
Hi, does anyone have, or know where I can get the 5 mm coolant pipe that runs from the Thermostat housing to the carburettors on a 2003 FZS600 please. It's about 7 inch long, it's not available from Fowlers. Failing that does anyone know where I can get a length of 5 mm (internal diameter coolant pipe, finding 6 mmm is easy but no one seems to stock 5 mm. Best regards... Cliff Briggs.
(26-04-18, 10:52 PM)cliff ilson link Wrote: Hi, does anyone have, or know where I can get the 5 mm coolant pipe that runs from the Thermostat housing to the carburettors on a 2003 FZS600 please. It's about 7 inch long, it's not available from Fowlers. Failing that does anyone know where I can get a length of 5 mm (internal diameter coolant pipe, finding 6 mmm is easy but no one seems to stock 5 mm. Best regards... Cliff Briggs.
Wouldn't 5mm reinforced flexible fuel line do it? Just a thought
https://www.ebay.co.uk/itm/COTTON-BRAIDE...SjoRkireKA
(27-04-18, 12:09 AM)tommyardin link Wrote: [quote author=cliff ilson link=topic=24079.msg279227#msg279227 date=1524779549]
[size=1em]
https://www.ebay.co.uk/itm/COTTON-BRAIDE...SjoRkireKA[/size]
That's a good shout, and probably 50 times cheaper as well for what you get.
https://www.advancedfluidsolutions.co.uk...2166-p.asp
