I need to remove the black fork cover from the top of the lower fork.
Are they easy do i rotate it and pull or what.
I don't want to damage the Alu or the fork cover...
the lower fork legs are going to be vapour blasted to clean them up so they need to be striped.
Hiya excuse a silly question but what is vapour blasting, sand, grit and bead I understand but vapour blasting???? Is it a sort of steam clean?
its high pressure water with grit in
its a softer approach than typical sandblasting and often better as it gives a smoother more uniform finish
so many people have carbs done this way but i am not a fan as the grit is not soluble and gets everywhere
stripped engines with big holes are fine and can be flushed but carbs should be soda blasted
(just for future refference that last bit - and im looking into starting a soda blasting/ultrasonic service when i get to preston lol)
