Strange noise :/
Hey i today I went for a little blast and noticed and strange whining noise coming from the front sprocket area that changes in pitch with speed , I can hear it above 40 onwards , do I need to worry or could this just be worn chain and sprockets ?
Chain looks fine because i clean and oil regularly.
Worried about a gearbox issue but the noise stays the same with clutch in or out
Set Fazer's to stun
i have a clicking from going down to that 14t on the front and wrecking the chain - im just going with a new chain this weekend if tool arrives
when did you last replace yours?
i say clicking but what i really mean is an unnerving clunking and as the last chain flung its link i am not taking that risk again as i was only doing about 20 at that time but 5 mins earlier was racing a mate at 110+ (close call much)
I went up to the 16t last summer so don't think it's a sprocket issue , I'll try the old 15t and see if it makes a difference on Sunday, chain is about 2 years old with 8000 (there abouts) on it, well looked after and adjusted correctly. Fingers crossed Its as simple as that
Set Fazer's to stun
(13-04-18, 10:47 PM)matt7chunk link Wrote: [size=1em]
[/size]
[size=1em]Hi Matt you say noise stays the same with the clutch lever pulled in or with it out, are you talking about still rolling along? I.e: free wheeling. If you are the whole drive train is still turning, so if it is a noise from the sprocket/chain/gearbox output shaft you will still hear it as the whole of that drive train is being dragged round by the momentum of wheels rotating on road rather than being driven around by the engine. But rotation is rotation no matter what causes it.[/size]
Yer freewheeling is what I mean,  really hope it's not the gearbox
Set Fazer's to stun
wont be the gearbox make sure the roller part  of the chain is well lubed with a decent chain lube , also make sure the chain aint too tight if so that causes noise , put it on the centre stand and run it up through the gears you will hear it better no doubt it will be the chain people tend not to realise how noisy they are
Have you touched the rear wheel recently at all, as in done any work whatsoever?
And, yes, you need to  worry right now, 'cos it ain't normal, if it wasn't there before then something is certainly not right!
(13-04-18, 10:58 PM)Disorderlypunk link Wrote: i say clicking but what i really mean is an unnerving clunking and as the last chain flung its link i am not taking that risk again as i was only doing about 20 at that time but 5 mins earlier was racing a mate at 110+ (close call much)
It popped off the hollow rivet master link? That's bloody scary! Do you know if it was definitely riveted properly?
not sure it just made a unholy racket so i pulled over on outskirts of town and noticed the chain was slack as fuck - limped into town so i could get my hands on tools and saw the link had bent to 45 degrees
my guess is the flare on the link wasnt done right by the last guy or even worse he used a u clip style link (was a newish bike to me)
(14-04-18, 08:23 AM)darrsi link Wrote: Have you touched the rear wheel recently at all, as in done any work whatsoever?
I have had the wheel off for cleaning swing arm and rebuilding re caliper, everything went back on properly though, the sound is definatly coming from the front sprocket area I'll try a get it on film tomorrow  ( work all day and night tonight )
Set Fazer's to stun
(14-04-18, 02:56 PM)matt7chunk link Wrote: [quote author=darrsi link=topic=24003.msg278329#msg278329 date=1523690608]
If you have the wheel off chances are you may have put it back on at a very slightly different position than it has been. This can cause friction on the plastic chain guide causing a buzzing noise until it beds in again, it will go away after a while.
(14-04-18, 03:01 PM)darrsi link Wrote: [quote author=matt7chunk link=topic=24003.msg278340#msg278340 date=1523714187]
The sounds doesn't seem that far back though, seems to come from right behind sprocket cover, I'll check out the guide tomorrow when I have another listen , I'll put the bike on centre stand with my small bike jack supporting the rear from bouncing and wind it up so you guys can hear it
Set Fazer's to stun
(14-04-18, 03:36 PM)matt7chunk link Wrote: [quote author=darrsi link=topic=24003.msg278342#msg278342 date=1523714504]
What i'm on about is near the front sprocket cover.
It's actually called a chain slider.
.png   Capture.PNG (Size: 301.72 KB / Downloads: 50)
ok so i got my new chain on today and i had the wine coming from the front as it had before but still the clicking at the back aswell
turns out the chain was fine and the sprocket carrier bearing had absolutly shit the bed
[smg id=3133]
the seals had gone and it filled with shite
(14-04-18, 05:52 PM)Disorderlypunk link Wrote: ok so i got my new chain on today and i had the wine coming from the front as it had before but still the clicking at the back aswell
[smg id=3133]
Proper shit the bed! I got a full set of bearings to fit soon front and rear , mine look ok but I'm just eliminating sources , I'll be interested to see if your whine is the same as mine at the front sprocket
Set Fazer's to stun
So I think it's cured now, slightly over tightened and worn chain I talk about it here skip to 2:10 https://youtu.be/DD3pGEyLhCc
Set Fazer's to stun
