25-03-18, 02:41 PM
Hey , as titled is isopropyl alcohol ok to clean chains without damaging the x rings? , its way cheaper than the aerosol cleaners on the market.
Set Fazer's to stun
Chain cleaning with isopropyl alcohol?
25-03-18, 02:41 PM
Set Fazer's to stun
25-03-18, 02:57 PM
Should be safe for O rings but it's not as cheap as paraffin.
25-03-18, 02:59 PM
ive been using citrus sol to good results - good for cleaning all sorts of greasy parts
riding this that and the other
vloggin some bits - https://www.youtube.com/channel/UCvWtJO9...R9RNHx72UQ https://www.instagram.com/disorderly_punk_yt/
25-03-18, 03:52 PM
I use WD40 for cleaning my chain.
25-03-18, 04:09 PM
(25-03-18, 02:57 PM)bandit link Wrote: Should be safe for O rings but it's not as cheap as paraffin.Isn't paraffin slippery as foc like diesel ? Not something I want near my tyres
Set Fazer's to stun
25-03-18, 05:14 PM
(25-03-18, 04:09 PM)matt7chunk link Wrote: [quote author=bandit link=topic=23912.msg277244#msg277244 date=1521986248]Isn't paraffin slippery as foc like diesel ? Not something I want near my tyres [/quote] Not as slippery as oil?
25-03-18, 05:18 PM
(25-03-18, 04:09 PM)matt7chunk link Wrote: [quote author=bandit link=topic=23912.msg277244#msg277244 date=1521986248]Isn't paraffin slippery as foc like diesel ? Not something I want near my tyres [/quote] You use a paraffin soaked rag to clean off crud then use a dry one after, unless your messy you shouldn't get any near the tyres.
25-03-18, 05:47 PM
I've got paraffin in a garden spray bottle and one of those spiral/cork screw chain brushes (very good!). I just prop some cardboard between the wheel and rear sprocket. Works very well and is as cheap as it comes.
25-03-18, 05:49 PM
(25-03-18, 05:14 PM)darrsi link Wrote: [quote author=matt7chunk link=topic=23912.msg277249#msg277249 date=1521990583]Isn't paraffin slippery as foc like diesel ? Not something I want near my tyres [/quote] Not as slippery as oil? [/quote] I had that one coming :rollin (25-03-18, 05:18 PM)bandit link Wrote: [quote author=matt7chunk link=topic=23912.msg277249#msg277249 date=1521990583]Isn't paraffin slippery as foc like diesel ? Not something I want near my tyres [/quote] You use a paraffin soaked rag to clean off crud then use a dry one after, unless your messy you shouldn't get any near the tyres. [/quote] Nice one bandit
Set Fazer's to stun
25-03-18, 07:42 PM
Paraffin here too. In a bottle with a squirty top cardboard between chain and wheel and Mrs Sharp's tooth brush.
And after
26-03-18, 09:12 AM
I buy a 4L container of paraffin from my local B&Q-lasts at least a year doing Tracer chain regularly. Protect tyre wheel & frame with newspaper. Have a dedicated chain cleaning brush that gets in the nooks & crannies then clean towelling rag and finally apply good chain lube or engine oil to clean chain.
31-03-18, 04:02 PM
(26-03-18, 09:12 AM)Dave48 link Wrote: I buy a 4L container of paraffin from my local B&Q-lasts at least a year doing Tracer chain regularly. Protect tyre wheel & frame with newspaper. Have a dedicated chain cleaning brush that gets in the nooks & crannies then clean towelling rag and finally apply good chain lube or engine oil to clean chain. 4L in a year! :eek that chain must be clean enough to eat your dinner off :lol
06-04-18, 11:04 PM
I'd be wary of using Isopropyl Alcohol on an O Ring chain - its very good at dissolving oils and greases, but also natural resins and it might affect the O Rings themselves, which could mean it might get past the O Rngs and dissolve the lubricant inside the chain elements.
We've used IA at work for many years fir cleaning work surfaces and simple tools, but we've always kept it away from rubber seals on machinery.
IPA sorts out carb icing lovely, not recommended for chains though.
Keep it simple, WD40 dissolves shite, but weirdly lubes as well. But then properly lube after as well. Wurth is my weapon of choice, done me proud so far.
07-04-18, 06:19 AM
Years of not cleaning the chain. Using a Scottoiler. Recent (last weekend) pics of the bike and the chain after a ride on some roads right after some rain(s), with mud washed over them as well.
07-04-18, 08:31 AM
I swear by white spirit, does a great job of cleaning the chain and other bits too.
At around £2 a litre you can't go wrong.WD 40 is in fact made up of over 80% white spirit. It's good for driving out moisture but not aggressive like ipa
07-04-18, 09:15 AM
(07-04-18, 08:31 AM)celticdog link Wrote: I swear by white spirit, does a great job of cleaning the chain and other bits too. Think it's about £2.99 a pint when the cider festival is on in most Wetherspoons. :lol
07-04-18, 10:32 AM
You still can not beat the price of paraffin and is totally safe and if you leave the lid off it wont evaporate like IPB but that is one trate that is not good because it wont evaporate away and stays around the links which is not ideal when you are trying to relube. So I either blast it off with air or brake cleaner with instantly evaporates. So lots of cheap paraffin and a small amount of more expensive brake cleaner.
07-04-18, 10:38 AM
I understand the idea of a scott oiler that it virtually constantly washes the chain as compared to a low fling wax type lube that will hold dirt and use a s a grinding paste, which is why the need to regularly clean. But I just don't like the ugly cable ties and the oil up my side wall and over the swing arm and up my boots and down Sharp Halls sweeping driveway.
07-04-18, 07:15 PM
(07-04-18, 10:38 AM)fazersharp link Wrote: I understand the idea of a scott oiler that it virtually constantly washes the chain as compared to a low fling wax type lube that will hold dirt and use a s a grinding paste, which is why the need to regularly clean. But I just don't like the ugly cable ties and the oil up my side wall and over the swing arm and up my boots and down Sharp Halls sweeping driveway. Didn't have any boot problems. Nor anything noticeable on a garage floor. But the bike's side does get some. For me it's a good trade off for not having to clean and lube the chain.
« Next Oldest | Next Newest »
