fellas, not at home right now but want to know what size socket required for rear wheel removal gen 2, cant remember if its 32 or 36 mm, also any tips on doing the task would be greatly foccing appreciated
Rear wheel removal question
24-02-18, 08:44 AM
32mm socket, pretty easy jobĀ bit heavy makes refitting awkward single handed or then again could be I'm just cacky handed
24-02-18, 02:49 PM
When refitting i always put the wheel on a wooden block the same height as the holes for the axle. That way after hooking the chain on you can push the wheel back in line and sort your spacers and stuff out without awkwardly holding up the wheel ?
« Next Oldest | Next Newest »
