Indicators
Morning all, this is my first post on this forum having recently bought a fzs600 2003 so hello from me... ?...it needs a fair amount of cosmetic work which I’m in the process of but my question to anyone who knows is.... I’ve bought some slightly smaller none led indicators, connected up the front... all works ok but as soon as I connect up just one of the rear the flash rate dramatically increases.... any ideas?
Quicker flashing means either a bulb is out, or you need a relay unit for the new indicators.
I understand that but there’s no bulb out and it only changes when I connect the rear, the front are on and work fine but then it increases as soon as I connect just one rear ?
Check the wattage of the bulbs, normal is 21Wats
