17-02-18, 11:36 AM
Morning focer font of all knowledge, some help please.
The previous owner appears to have done the headlight mod but it doesn't always work. Sometimes I have one light, sometimes two. What I've never had is a working passlight switch.
I'm replacing my fairing so thought I would have a look at what's going on, but like always, my knowledge is small so some help please.
I've got an addtional wire on my right hand lamp (when sitting on the bike) and I've tracked it back to the connections box.
This wire goes to a 20A fuse (seems far too big a fuse to me, what do you think?) and then it goes to a green wire that's been snipped.
I'm guessing this green wire is what operates my passing switch and they've taken this feed to do the headlight mod, would I be right?
Hopefully the atttached pictures should help show you what's going on.
So, questions:
Have they done it right?
Have they done it safely? (that fuse seems far to big to me).
Am I right about why my passing switch doesn't work?
I'm guessing a loose connection is probably the reason why the mod works/doesn't work?
Should I keep the mod or put is back to how it was? I'm not bothered about the twin headlight mod. And if I do, do I just join that green lead back together? There doesn't seem to be anything else cut.
Cheers guys
So, questions:
Cheers guys
