rattle in clutch basket when hot
Hi fellas should i just change basket or change clutch/bearing bush etc --never done one before but cant be that hard any tips or advice greatfully accepted --oh this is a 72 000 mile bike ??
MY GRANDAD TOLD ME -WHAT DOESNT KILL YOU MAKES YOU STRONGER--EXCEPT FOR A BEAR THAT WILL DEFINATELY KILL YOU---
check to see if its the basket cush springs start it let it idle it should rattle pull the clutch in if the rattle goes away then its the basskes cush springs that are worn and not a replaceable item so either a new basket  mega bucks live with it , take a chance on a second hand one or try a repair on it yourself youtube has videos of other bikes but its the same principal
If it gets quieter when you pull the clutch in nothing serious to worry about.  They all do that at the miles mount up.
