Rocker cam cover end caps colour
Hi, Anyone have the colour code to the silver rocker cam cover end caps for 2002 fzs 600 foxeye?
I have two with deep scratches that I would like to refurbish. Also need to respray cooling fins and stator covers. I've ordered enamel black gloss for the covers and hoping to buy enamel matt for the fins.
Just can't seem to find anything on the end caps.
Also what have others used to paint or spray the high black gloss frame?
I've a few rusty patches especially around the nose cone struts.
Thanks guys
the paint on my frame was coming away when i bought it in rough shape so i just scraped away the crappy flakey paint and coated with hammerite smooth to protect from the evil tin worm,
when it comes to the rebuild i will probably be using pj1 fastblack epoxy paint as i have heard good reviews on it
if you choose this to patch areas then make sure you use rust remover or kurust otherwise it will flake off again
