Bargains?
1. Halfords have got 20% discount on all Castrol 4 litre oils at the moment. Making 10/40 Power 1 = £31.20 and Power 1Racing = £32.80. Probably cheaper than anywhere else at the moment?
2. Lidl have got an intelligent battery charger which can be switched between bike (less than 14ah) and car (14ah to 120ah). Price £13.99. OK for lead/acid, AGM and GEL Also can charge 6v.
That's still bloody expensive for oil.
Not for Power 1 Racing it isn't
The marketing spiel is designed to get you hooked, but it's still oil at the end of the day, that has to be of certain specs and regulations, otherwise engines would be going pop left, right and centre.
I wanted to try fully synthetic for a change so tried this stuff out for quite a while now and i've been more than happy with it, with no issues whatsoever.
As long as the oil is changed within the recommended intervals then you shouldn't have any problems. The 600's are given a 6000 mile recommendation, but me, along with quite a few others tend to change it around the 4000 mile mark, so paying over the odds for it isn't too appealing just because it has a fancy name on the container.
The semi synthetic is even cheaper, but if you haven't bought any already give this gear a go, i promise you won't be disappointed.  Wink
http://www.ebay.co.uk/itm/5L-Fully-Synth...SwHQ9WXgZf
http://www.ebay.co.uk/itm/5L-10W40-Super...SwoydWj6~Y
You can get 5 Litres of Semi-Synthetic 10W40 at Wilkos for £15.50 http://www.wilko.com/car-maintenance-pro...vt/0257972
Well I like Power 1 Racing, hence the bargain. Running 2 Triumphs as well as the Fazer, both specifying fully synthetic.
Tried the Lidl battery charger today and looks to do all that the much dearer 'specialist' bike ones do.
Cracking shout there darrsi, after checking it out via the link I will be defining giving it a try. Cheers
Oh I forgot to add aldi also have battery chargers in at the same price, I picked one up last week & I'm happy with it ?
(23-09-17, 09:27 AM)darrsi link Wrote: The marketing spiel is designed to get you hooked, but it's still oil at the end of the day, that has to be of certain specs and regulations, otherwise engines would be going pop left, right and centre.
Why are you changing it sooner than recommended? Do you doubt the oil quality, or some other reason?
API SL and JASO MA2 seem very promissing.
What's the (not petrol station rip off) price of Motul 7100 10w40 in the UK?
(24-09-17, 03:10 PM)Slaninar link Wrote: [quote author=darrsi link=topic=23301.msg268613#msg268613 date=1506155264]
Just something i've always done, i don't do a lot of mileage really so it's not as often as you'd think, probably once a year so it's no problem.
I consider it time to change it around the 4000 mark, but also know i'm in no hurry and it's not an urgency.
For those looking to break into the MotoVLogging ting.....
(Price drop)  Wink
GoPro HERO Session Full HD Action Cam [Built in Wi-Fi / Bluetooth / Waterproof upto 10M] now £139 @ Argos (2 year guarantee)
Good price here on a blackshadow rear disc that fits the FZS600. British made to boot  Smile
http://www.ebay.co.uk/itm/Ducati-Monster...440cc6f8ef
(05-10-17, 08:59 PM)celticdog link Wrote:Good price here on a blackshadow rear disc that fits the FZS600. British made to boot  Smile
You sure it fits?
(06-10-17, 01:34 PM)darrsi link Wrote:[quote author=celticdog link=topic=23301.msg269252#msg269252 date=1507233551]
You sure it fits?
I hope so cos I've bought one!
(06-10-17, 06:07 PM)celticdog link Wrote:[quote author=darrsi link=topic=23301.msg269277#msg269277 date=1507293281]
You sure it fits?
I've been on the lookout for a new rear disc, i just can't stand the thought of going through all the grief of changing it though after the last one turned into a nightmare.
It's okay for now but it will need changing soon.
(06-10-17, 06:55 PM)darrsi link Wrote:[quote author=celticdog link=topic=23301.msg269290#msg269290 date=1507309643]
You sure it fits?
What happened?
(06-10-17, 07:06 PM)rlkat link Wrote:[quote author=darrsi link=topic=23301.msg269297#msg269297 date=1507312540]
You sure it fits?
What happened?
Every bolt refused to budge apart from one, which i got half way out with brute force, then it snapped off in the wheel hub.
I did try heat at the time, although maybe just not enough, but as i needed the bike on the road asap for work i came to the conclusion that a new wheel with the tyre swapped onto it was the quickest and cheapest option rather than pay for someone to try and remove the bolts then maybe find out it was a waste of time and money.
Because of the direct heat transfer to the fixed disc when braking the bolts fuse themselves to the wheel hub making them a major headache to remove.
The disc bolts should have thread-lock on them which makes them difficult to undo. You need to give each bolt plenty of heat to release the thread-lock. They are still a devil to get undone and normally make a good crack noise when they start to turn.
When you put a new disc on it's best to also use new bolts with thread-lock, you can use your old bolts if they came out ok and the Allen bolt heads haven't gone sloppy but new ones don't add too much to the cost and I've always thought that bolts that have been heated are weaker which is not a good idea on the most important part of your bike.
(07-10-17, 04:24 AM)Hugh Mungus link Wrote:The disc bolts should have thread-lock on them which makes them difficult to undo. You need to give each bolt plenty of heat to release the thread-lock. They are still a devil to get undone and normally make a good crack noise when they start to turn.
All good stuff thanks. I'm going to enlist the help of a car mechanic mate with a gas bottlle, lets hope it's a straightforward job.  Smile
Firstly, do they even need threadlock, 'cos i seriously cannot imagine them ever coming loose if torqued properly?
And secondly, as the disc is being changed, would it not be a great idea to take the bike for a spin and use a lot of rear brake, because that will heat all the disc bolts up anyway!
You really need a blow torch on them so they're really hot.
I use thread-lock because the bike manufacturers do. They're renowned for cutting down on grease etc so if the disk bolts didn't need thread-lock they wouldn't put it on.
