Battery
Finally getting my old girl on the road after couple months. Battery flat as a pancake and I'm hoping it is only the battery.
So is it worth picking up a "Yuasa YT12B-BS Powersport Motorcycle Battery" from halfords or is there another to look out for.
I have a 2000 fzs 600
Thanks
Dont shell out for a new until you know the old one is shagged. Should measure 13 to 13.5 volts charged up
Where are you located?
I have a brand new motobatt that size, purchased in error (well sent to me in error) I have a 1000 and it needs the 14 not 12.
If you are anywhere near Liverpool you can have it for £25, which is less that half price, saw similar size in Halfords for £99  :eek
Kev
+1 for motobatt  :thumbup  never had a problem with it charges up easy if you've ever left the parking lights on by mistake.
Halfords are full retail prices. Many auto factors stock bike batteries and are loads cheaper, as is on-line. Halfords wins on Saturday afternoons and Sundays only in my world, and even then only if really really urgent.
is it clean enough?
At least charge it up first to see if it works okay, it might be absolutely fine.
Yes defiantly try charging first. I have this one - or very similar with yam branding and supposed to bring back to life dead battery's it can also be used as a optimiser and comes with permanent battery leads for quick plug in.
(12-08-17, 12:17 PM)fazersharp link Wrote: Yes defiantly try charging first. I have this one - or very similar with yam branding and supposed to bring back to life dead battery's it can also be used as a optimiser and comes with permanent battery leads for quick plug in.
There's a big difference between a flat battery and a dead one.
No amount of charging, no matter how fancy the charger is, will revive a battery that has knackered cells.
(12-08-17, 02:49 PM)darrsi link Wrote: [quote author=fazersharp link=topic=23046.msg265988#msg265988 date=1502536649]
Yes agreed - dead and flat are two different things but people use both to describe the same thing.
(12-08-17, 02:49 PM)darrsi link Wrote: There's a big difference between a flat battery and a dead one.
But a dead one can also *appear* to be good, because even if it has a dead cell, it can still read full volts.
The only way to check is to put a drop-tester on it to see if it's actually holding the charge.
Even new battteries can turn out to have a duff cell Sad
