FZ6 for sale in London. Needs supplied frame fitted
This is also on ebay and more photos are there
http://www.ebay.co.uk/itm/142461132432?s...1558.l2649
For sale is my Yamaha FZ6, which I bought from someone who only did the first 950 miles, so I have almost had it from new. I am listing this for parts as the main cast frame has a crack in it. This was not caused by an impact. I showed it to Yamaha, who have provided a free issue replacement new frame even though the warranty long expired. This wold cost you £1300 if you bought it. If you have the skills to replace this then you'll have a fine bike. Or it will cost about £5-600 at a garage. The front fork seals also need replacement, but this won't be a major job as you will have to remove them anyway to replace the frame, and the parts are cheap.
I have used this bike for commuting 13 miles into central London. It is garaged, but has age-related paintwork. It has some scratches from a <20mph spill but has never been impacted in a crash or slid down the road into anything. I took this out for a quick spin today and it is running very well.
  • Top box included with two keys. Givi plate can be removed and a Yamaha box will fit the rack
  • Heated grips. You'll be thankful for this in winter. Also included are neoprene Turcano hand muff things.
  • New DID chain and new sprockets fitted not long ago.
  • Pipercross cleanable performance air filter
  • New clutch a while ago
  • Accessory connectors fitted on relay, so you don't have to remember to turn off. Heated grips are on the same circuit.
  • LED lights fitted inside crash bungs
  • Haynes manual, new oil filter and any other spares I can find included. Printed copy of the full workshop manual
  • Two black bike keys and the red security one, and two top box keys
  • Tyres 70% good on grip wear, and slow leak on the rear.
  • Engine and gearbox are still very crisp despite quite high mileage. Exhaust is good with no rust
  • Serviced annually with oil change, filters. Valve clearances checked recently with no adjustment necessary.
  • For clarity, the new frame and associated new parts will be included but not fitted.
Let me know if you have any questions, or you would like to come and view. The bike is currently SORN.
Bye.
A video of the bike can be found at:  https://youtu.be/JIYOO6aHCl0
