[color=rgb(29, 33, 41)]FZS fazer 600 parts for sale from both models:[/color]
[color=rgb(29, 33, 41)]Foxeye parts available please see list lots already sold basically what's left is in this advert
Tank overall GC few scratches in lacquer,a very tiny (barely noticeable) dent has no rust inside £80
Side panel tail unit yellow vgc SOLD
Front Mudguard black metallic paint £30
Wiring loom £35
Cdi unit £20
Starter solanoid £10
L&R switches £15 each
Rear shock SOLD
Rear swing arm £20
Head cams,shims & rocker cover etc in vgc £80
Barrels & pistons SOLD
Sprocket carrier
Cush rubbers
Sprocket cover
Generator cover SOLD
Left frame panel
Left airbox panel
Clock set
Starter motor
Rear light
Rear light bracket
Clutch cable
Cam chain tensioner
Fuel tap
Fuel gauge
Engine mount & bolts
Thermostat & all pipes
Side stand
Side stand switch
Rear brake torsion bar
Shock linkage
Front & rear spindle
Bottom yoak[/color]
FZS Boxeye parts
Frame,s/arm,sidestand + switch etc see pics inc V5 old mot's etc £60 can post at cost via palet
FZS 2000 bottom end complete SOLD
The front fairing has SOLD
Fairing h/light bracket SOLD
Fairing alloy brackets £10
Front mudguard SOLD
Rear tail panels £30
Tank now SOLD
Lockset top yoak inc switch,petrol cap & seatlock 2 keys SOLD
Wiring loom in vgc SOLD
Left & right switches £15 each
Generator inc cover £50
Reg/rectifier £15
Throttle £13
Rear light £5
Rear frame mudguard not cut or damaged £15
Right hand riders footpeg inc brake lever
Spindles front & rear plus spacers
Cush rubbers
Sprocket cover
Starter motor
Rear light
Rear light bracket
Clutch cable
Cam chain tensioner
Fuel tap
Fuel gauge
Radiator inc fan
Side stand
Side stand switch
Right riders footpeg inc brake lever
Shock linkage
Bottom yoak
Sprocket carrier
Wheels front & rear £10 each postage to uk mainland is £10 each
Wiring loom £35
Cdi unit £20
Rear shock SOLD
Rear swing arm £20
Sprocket carrier
Cush rubbers
Sprocket cover
Left frame panel
Left airbox panel
Clock set
Starter motor
Rear light
Rear light bracket
Clutch cable
Cam chain tensioner
Fuel tap
Fuel gauge
Side stand
Side stand switch
Shock linkage
Bottom yoak[/color]
FZS Boxeye parts
Front mudguard SOLD
Tank now SOLD
Reg/rectifier £15
Throttle £13
Rear light £5
Cush rubbers
Sprocket cover
Starter motor
Rear light
Rear light bracket
Clutch cable
Cam chain tensioner
Fuel tap
Fuel gauge
Radiator inc fan
Side stand
Side stand switch
Shock linkage
Bottom yoak
Sprocket carrier
Stuff everything I've always got my bike
