Have been having a good sort out & am offering the following items to anyone interested. Before anyone says "Thats not much cheaper than dealer/ebay etc" please note the price stated includes all postage/packing costs.
1 Hiflo HF147 Oil Filter £6
1 Drain plug crush washer FREE WITH ABOVE OR £1 bought separately
1 Hiflo HFA 4606 Air Filter £12
4 NGK CR8E spark plugs £20
1 Yamaha Front Sprocket Upgrade Kit part no 90891-10124 (contains 12mm nut & lockwasher) £5
1 Yamaha "Collar" part no 90387-126T1 (illus no 16 in online parts drawings-REAR SUSPENSION) £10
2 "Marksman" supplied high quality caged needle roller bearings for above (half the price of OEM part no 93317-41761-illus no 15 in online parts list) £15 the pair. nb Price for Collar & Bearings together is £20.
* the above 2 items namely collar & bearings fit EITHER under swing arm OR in LONGER of the 3 sections in the pivot assembly at base of rear shock.
1 complete set "Marksman" supplied CODEX brand high quality tapered roller bearing headset complete with seals, unopened £20
1 Fairing Infill panel Yamaha "Rivet" part no 90269-07076 £1
4 Chrome finish Yamaha plastic caps for handlebar clamp bolts part no 90338-08163 £4
1 Rear Brake caliper centre o ring (small) that seals the two halves of caliper when split for overhaul etc. £1-50
1 Pilot Screw & washers with FREE 8 small o rings included for carb overhaul Yamaha part no 5DM-14105-00 -Suits carb type fitted to 2000-2001 model year £20 ( Yamaha price £30-71)
Please PM for payment details or any further info.
Many Thanks, Dave
Many Thanks, Dave
