HiH
HiH
Hiya
HiH
Hiya[size=1.35em]Hiya [/size][size=1.35em]Got an issue with one indicator intermittently not working while the front panel instrument goes bananas, showing full tank, wrong indicator flashing (actually solid) and other anomalies. Traced it to one loose fitting wire in the female section of the terminal block (black-coloured wire in pics). Looks like the plastic around that wire is burnt and I assume this means the whole block will need replacing rather than just the end pin on that black wire?
Anyhow, just looking for suggestions as to where to find the appropriate block. [/size]Maybe B&Q?
[size=1.35em]I'm not that confident with pressing new pins onto wires so, if I'm going to fix it myself, it will ideally need to be a block with screws. Will cut all the wires in the female section of the block and fit them into the new (screw) terminal individually.
[/size][size=1.35em]The far more expensive option is to get a shop to do it of course, although cheaper than me frying the whole bike [/size][size=1.35em]
[/size]
[size=1.35em]Thanks[/size]
HiH
Hiya
HiH
[/size][size=1.35em]Thanks[/size]
