09-07-17, 08:47 PM
Hi, my 1999 FZS 600 has been running like a dream however, last week she has stated to play up. Really have to push down hard to select first gear and second is tricky too. I have oiled the clutch cable and greased and adjusted the clutch rod pusher but not really any difference. What is interesting however is when the bike is on the centre stand - and you engage 1st gear with the clutch pulled in, the rear wheel starts spinning (can't stop it with your hand) - like the clutch is dragging. If anything, the clutch probably needs replacing which I have know about however, I thought this would have caused slipping - not dragging!
Can anyone help? I'm really hoping it's not a gear box re-build :eek
