Ear Plugs
I've always worn earplugs when riding and have always brought a job lot from earplugsbypost.com  It's that time again when I need to by a new pack.  My current ones  are 3M 1100.
Always good to have new ideas, so, what do you use?  Either disposable of those "posh" molded ones.
Used 3m ear soft fx for past few years. Work well for me. Heard mixed reviews on custom moulded so have always resisted forking out with a risk of disappointment.
Ear plugs ear plugs I think I must of have tried most of them. I have an issue with narrow ear canals and one is slightly bent, both issues don't help the natural flow of wax and so I don't stuff the plugs down as mush as they are supposed to go which then leads to the issue of them ripping out when I put my lid on - or off.
I have brought a packs of mixed sizes and shapes to test.
Alongside normal plugs I have tried mould your own - admittedly with a cheap product called silicone putty, the idea being that it only slightly gos in and covers the ear hole. It was great when it was wet and I kept my mouth in a set position while it set but once it was set and I re tried them in they seemed slightly small and didn't do much sound blocking.
I have tried the soft wax plugs that distort when I pull my lid on and so don't help much with noise.
I have tried Docs proplugs - that despite my best efforts in correct sizing do not fit correctly to cut out enough noise.
After all that expense  and faf I have come to the conclusion that I am best to go for any standard to fatter plug - cheep will do and then cut off the last 1/3rd, as I am not sticking it all the way in the last bit sticks out and causes the issue with my lid ripping them out.
As I am only partly inserting them I have to keep pressure on them until they have expanded and grip so what I really would like to find out is which plug re - expands the fastest so I am not standing around with my fingers in my ears waiting for them to expand.
I use the Dial ones from B&Q. Cheap and really effective. They're nice and soft and easy to insert. I generally reuse them for a few days before using new ones but always store them in separate packages so I know which one goes in which ear (just in case there's a bug).
Malc
Old enough to know better.
I like the Howard Leights, pink and yellow ones. I buy boxes of 500. Roll them up small and shove them in until they are touching my ear drum. Very quiet, very comfortable.
I carry reusable Thunderplugs on my key ring for day to day noisy stuff (clubs, pubs and gigs)
https://www.amazon.co.uk/gp/aw/d/B00LSOP...underolugs
-suck-squeeze-bang-blow-
These
http://www.ebay.co.uk/itm/200-pairs-Howa...SweW5U9WjZ
After 40 years down a ships engine room my ears are fuc-ed anyway .I start out with them in and always forget to put them back in after a coffee stop so tend to say feckit now.
They're pretty good actually, been usury them for years in work and on the bike.
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
(07-07-17, 08:47 AM)fazersharp link Wrote: Ear plugs ear plugs I think I must of have tried most of them. I have an issue with narrow ear canals and one is slightly bent, both issues don't help the natural flow of wax and so I don't stuff the plugs down as mush as they are supposed to go which then leads to the issue of them ripping out when I put my lid on - or off.
Have you tried small tampons, i mean it's not like you're gonna get them wet?  :rollin :rollin :rollin
Had some moulded ones, not pleased, the foam ones, rubbery type are the best.
Oh , if you go into builders merchant and ask they may give them away, who are the ones with the blue lorries ? Ummm, they have a bag in Hereford and they give you them, last time I had ten pairs free,
I like the EAR Classic.
Classed as disposable, but you get plenty of repeat use out of one pair, and if yer tight you can wash em.
https://www.amazon.co.uk/Classic-Foam-Di...AR+CLASSIC
Pardon?
Horses for courses.
For long distance motorway travel I use swimmers putty.
I've more or less tried all the health and safety plugs out there that are available but the problem is eventually they all hurt once they've been in for a while.  For long distance mouldable silicone is way better, other than paying for bespoke plugs. They cost a wee bit more but they're worth it, just my opinion based on my experience. Smile
(08-07-17, 12:20 AM)celticdog link Wrote: [size=1em]Horses for courses. [/size]
[size=1em]For long distance motorway travel I use swimmers putty. [/size]
I have tried the macks silicone and found that it displaces when I pull on my lid and does not cut out much noise.
The swimmers putty you mention and the mouldable silicone are you referring to the same thing - the swimmers putty or are they two different things you have used.
Any links on the swimmers putty please.
(07-07-17, 10:25 PM)VNA link Wrote: I like the EAR Classic.
These were the very first ones I tried years ago and remember that I got on ok with them, I have since been lost in the mass ear plug market trying all kinds of exoctic types in the quest for a perfect fit, I think I need to re visit these
Cheers guys, sounds like I'm on the right lines with the ones I've got, personal choice I guess with no overall winner.  I shall carry on as I am :-)
(08-07-17, 09:34 AM)fazersharp link Wrote: [quote author=celticdog link=topic=22877.msg264144#msg264144 date=1499469631]
This is the one I use, one plug will make 2 earpieces.
http://www.ebay.co.uk/itm/Zoggs-Silicone...2144648955
