R6 Throttle tube mod - Can't feel any difference
Hi everyone,
I have a 2014 Fazer 8, and I tried to modify it by changing its throttle to an R6 for a shorter WOT.
I ordered Motion Pro 01-0094, tried it, but felt no difference.
So I decided to compare both original tube vs. the Motion Pro (Color White). If you check my attached photos, it seems that they have the exact same diameter?
1. Am I wrong?
2. Which tube can I use to shorten the WOT?
3. Where do I place the black plastic ring? does it go inside the plastic cap grip, or outside it?
Thanks.
both tubes have a 3cm part that the cable wraps around so you wont see any difference at all.
