Oil Leak
Hi guys
Just went up to my bike (it's been stood for 4 days not started or anything) and notice a tiny puddle of oil.
The bottom of the slump is covered in oil as well but it appears to be coming from even higher than that.
Oil level has gone down but not by much. I have attached a few photos of the problem.
Can anyone let me know where they think the leak is coming from and why and how to sort it out please.
Thanks in advance.
.jpg   19433559_10213669229313312_1520408258_n.jpg (Size: 81.19 KB / Downloads: 56)
.jpg   19478178_10213669229793324_1156686931_n.jpg (Size: 79.36 KB / Downloads: 56)
.jpg   19427769_10213669229473316_927212584_n.jpg (Size: 77.17 KB / Downloads: 56)
Has the crankcase breather hose split or come adrift?
Otherwise it might be a leaky cam cover gasket.
The inlet rubbers look to be oil free so I would suggest it isnt coming from the top end of teh engine. Theres no oil near the carbs apart from, as Fazerider says, the crankcase breather.
Check inside the airbox to see if thats full of oil.
Looking at the pictures under the engine, teh oil is coming from the back ratehr than the front which ties in with teh oil under the carbs.
(23-06-17, 06:23 PM)BBROWN1664 link Wrote:The inlet rubbers look to be oil free so I would suggest it isnt coming from the top end of teh engine. Theres no oil near the carbs apart from, as Fazerider says, the crankcase breather.
So most likely is it coming from the gasket?
What about all the hosing around that area, they are covered in oil is there any chance it could be leaking from one of them?
Its difficult to tell from the pictures but is there oil on the inlet rubbers? I cant see any in the pictures but cant be certain. If theres none on the rubbers, and the bottom half of the cylinder block looks dry too, the oil has to be coming from behind the carbs or above.
Oil will only flow downwards unless there is a good breeze. The oil on the hoses will have come from the carb above it.
I'd guess the cam cover gasket. Did you top up the oil recently? It might be over filled.
(23-06-17, 07:16 PM)Grant1Shepherd link Wrote:What about all the hosing around that area, they are covered in oil is there any chance it could be leaking from one of them?
None of them should be carrying oil. Fuel, air and coolant but no oil.
The crankcase breather will have a light oil mist present, but if there's a lot of blow-by past a piston or the engine's been overfilled it can be a bit more than that.
(OK, there is a drain for the airbox which can dribble oil blown into the box by the breather, but it's hard to see how that could get on the carbs as it's routed to drip on the ground behind the engine.)
